Штатное двух-ядерное ГУ на Android 4.2.2/4.4.X
Тема для обладателей подобных ГУ. Обсуждаем, делимся опытом, программами прошивками.
Android 4.2.2                                                      Android 4.4
post-7637-0-06074500-1418366060_thumb.jpg post-7637-0-92836000-1418366058_thumb.jpg
На китайском рынке существует две модификации различающиеся только* диагональю экрана.
Технические характеристики:
Hot Selling:
— OS: Android 4.2.2 / Android 4.4.X
— Nand(flash): 8G
— HD: 1080P
— Storage memory: DDR3 1GB
— CPU: A9 processor with Dual- Core
— Multipoint Capacitive screen (6 points)
— Smart App Updates
— Screen Mirroring Function for iPhone, Samsung Galaxy(android 4.2).
— Change the theme by yourself.
— Support original steering wheel control to work with the car DVD player
— 34 different car logo to match different brand of car.
— Multi-language Menu OSD Language(10): Russian, Turkish, Arabic, Italian, Portuguese, Chinese, English, Spanish, German, French
— Support 3G module
— HD Resolution: 1024 * 600 (option)
Screen
— Screen Size: 6.2 or 7.0 or 8.0 inch high definition LCD Monitor
— Resolution: 800*480(WVGA)
— Touch Screen Function
— Image Brightness /Contrast/ Color Adjustable
Bluetooth
— Built-in Blue tooth hands free call
— Support Bluetooth MP3 Player Function
(Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output)
— Support NFC (Attention: Require mobile phones equipped with NFC. )
— Support Bluetooth Phone Book Function
— Support Bluetooth Connection for iPhone/iPhone 3G/iPhone 3GS/iPhone4/ iPhone 4s
3G & WIFI
— Support 3G module (Need 3G adapter)
— Built-in Wifi Module
GPS Specification
— Operation system:Android 4.2.2 / Android 4.4.X
— CPU: RK3066 1.6GHz Cortex A9 Dual-Core
— Chipset: U-BLXO G6010 ST 瑞士进口
— Nand(flash): 8G
— Channel number: 20 channels
— GPS port: COM2
— GPS Baud Rate: 9600
— Tracking sense degree: -159dbm
— Position Accuracy:10m, 2D RMS 5m, 2D RMS, WAAS enable
— Max altitude: 18,000 M
— Max velocity: 515m/s
— GPS dual zone function:Work navigation while listen to music at the same time
— GPS language:Japanese/Russian/Chinese/German/Italian/French/Arabic/Greek/Polish/Portuguese/Dutch
— GPS audio :work with front & rear speakers
— GPS map:Free demo map with SD card is ready
IPOD/IPHONE
— Support iPod Input & Charging
— Support iPod Models: IPOD and Iphone with new Interface(Iphone5 above)
— Support audio only :( Track List, Name display, Album, Singer's info)
USB/Micro SD
— BuiltIn USB Port/Micro SD card Slot
— USB2.0 Port:Support USB flash drive with maximum 32G compatibility, but cannot support portable hard drive.
— Micro SD Card Slot: SD2.0 protocol standard SDHC, support 32 GB as Max
— Available Video Formats: MPEG-1/2/4、H264、H263、VC1、RV、RMVB、DivX、Sorenson SparK、Spark、VP8、AVS Stream
DVD
— Compatible Formats:
— DVD, DVD-R, DVD-RW, HDVD, DVCD, MP3,MP4,MP5,CD-R, CD-RW, VCD, DIVX, etc(MP5 need to decode).
Radio
— BuiltIn Radio Tuner (30 Preset Stations)
— FM(3*6): 76.0MHz-108.0MHz
— AM(2*6): 522-1620KHZ
— BuiltIn RDS Radio Receiver Function(Europe)
Прошивки Android 4.2.2 (800x480):
Прошивки Android 4.4.2 (800x480) - не работает Torque и др. стороннее ПО работающее с БТ:
Кастомные:
KLD2_KitKat_800x480_141110 от booroondook (источник)
Отличия от стоковой версии:
  • Сразу после прошивки - русский язык, московский часовой пояс (GMT+3) и разрешение на установку сторонних приложений.
  • Исправлены часовые пояса (версия 2014i). В частности, возвращено "зимнее время" для России.
  • Предустановлен root-доступ***, менеджер root-прав - Superuser (желающие могут установить из Маркета SuperSU).
  • Занимаемый объем раздела system снижен со штатных 768 МБ до 512 МБ, чтобы высвободить неиспользуемое пространство.
  • Максимальный объем раздела data увеличен с 1 ГБ до 3 ГБ, что позволяет на практике отказаться от переноса приложений на карту памяти.
  • Фактический объем раздела oem увеличен до занимаемого (с ~50 МБ до 128 МБ), что позволило разместить на нем комплект предустанавливаемых приложений.
  • Заменен стартовый логотип системы - добавлена символика 4PDA.
  • Переделан аварийный загрузчик (recovery.img) - измененный recovery базируется на стоковом recovery от версии KGL-20140903 (Android 4.2.2) с ядром от KGL-20140514 (Android 4.2.2) - просьба не путать основное ядро системы с ядром recovery. Причина замены - штатный recovery 4.4.2 не создает журналы работы, а при попытке установки несертифицированного патча может вызвать циклическую перезагрузку в режиме recovery.
  • В recovery добавлен мой личный сертификат для возможности установки подписанных обновлений и патчей****.
  • Переделан основной загрузчик (boot.img) - добавлено создание символических ссылок на носители в папке /storage, а также создан сервис предустановки приложений.
  • Установлен busybox в комплекте со всеми своими символическими ссылками (папка /system/xbin).
  • Удалены менеджеры китайской и японской клавиатуры (PinyinIME.apk и OpenWnn.apk, соответственно).
  • Удалена устаревшая версия "Голосового поиска Google" - желающие могут установить это приложение из Маркета.
  • Исправлен русский перевод штатных приложений.
  • Исправлены макеты (интерфейсы) штатных приложений с целью сделать их одинаково отображающимися вне зависимости от плотности экрана.
  • Исправлена ошибка в приложении "Видеорегистратор", связанная с неотображением геолокационных данных при воспроизведении записи.
  • В приложение "Настройки" добавлены пункты "Ещё -> Ethernet", "Местоположение" (продублировано путем выноса копии на верхний уровень), "Для разработчиков", "Об этом устройстве -> Дополнительные обновления системы" и "Об этом устройстве -> Юридическая информация"
  • Приложения "Gmail" и "Google Maps" переведены из системных приложений в предустанавливаемые пользовательские.
  • Сделана возможность установки обновлений как "по воздуху" (технология OTA), так и вручную (установка патчей).
  • Создан сервис предустановки приложений при первой загрузке после перепрошивки или сброса к заводскому состоянию.
  • Доступность в Маркете для ранее недоступных приложений (Яндекс-Навигатор, RoadAR и др.) - решение взято отсюда с подачи Malaysk.
  • Добавлен мой личный сертификат для возможности установки подписанных обновлений и патчей****.
  • Перечень предустанавливаемых приложений: Adobe Reader, Gmail, Google Maps, Chrome, Titanuim Backup, True Contacts, Эмулятор терминала, Root Explorer, Car Audio Service, DPI Changer, а также комплект Xposed (Xposed Installer, App Settings, XposedMTC, GravityBox-KitKat).
  • Изменен список OEM-приложений. Он расширен за счет предустанавливаемых приложений. То есть, любое случайно или преднамеренно удаленное предустанавливаемое приложение можно установить заново с помощью приложения "OEM".
  • Добавлен сетевой идентификатор (hostname) "HeadUnit", позволяющий однозначно идентифицировать ГУ в информации маршрутизаторов и точек доступа.
update_4_4_2_800X480_KLD_2_MAL от Malaysk (источник)
Основа от прошивки KLD версии андроидной части 4.4.2 800X480
Что добавлено,изменено,удаленно:
1. В прошивку встроен ROOT,стоит менеджер для ROOTа SuperUser (SU) (отлично обновляется из Play Marketa), busybox.
2. После установки прошивки по умолчанию стоит русский язык,часовой пояс +4 (Москва),можно ставить сторонние приложения.
3. Раздел для установок программ с 1 гб увеличен до 2 гб
4. Убраны значки при включении задней скорости, т.к. лично мне они только мешали.
5. Добавлено в Настройки Меню Автозагрузки.
6. Исправлена недоступность некоторых программ в Play Markete (Яндекс Навигатор,Радар Стрелка и других)
7. Добавлены гугловские сервисы ,CHROME обновлен до последней стабильной версии
8. Добавлен файловый менеджер ES File Explorer
9. Добавлен файловый менеджер Root Explorer
10. Добавлен Titanium Backup Pro полный
11. Добавлен ® Xposed. Нужно будет зайти в программу и активировать Xposed framework (обязательно перезагрузить устройство)
12. Добавлен XposedMTC. Нужно будет сначало запустить в программе Xposed Installer сам framework(читайте пункт 11) и активировать в ней XposedMTC в разделе Модули (обязательно перезагрузить устройство)
13. Удален стандартный Musik.apk (стоит системный MTCMusic)
14. Удалена китайская и японская клавиатура.
15.Добавлено в Настройки-Экран-Управление траффиком. Где можно включать,выключать,изменять цвет отображения траффика в шторке уведомлений.
16.Добавлено в Настройки-Система-Плотность экрана. Где вы сможете установить подходящую вам плотность экрана. Мои рекомендации, установите 200-220 dpi
17.Добавлено в Настройки-Экран-включение панели приложений в шторку уведомлений.
18 Изменен стиль часов и шторки уведомлений.
19. Другие исправления и дополнения.
На фотографиях есть кнопка Выключения и Перезагрузки, я её не добавлял...это для себя сделал.
http://4pda.ru/forum/dl/post/5386324/1.jpg
http://4pda.ru/forum/dl/post/5386325/2.jpg
http://4pda.ru/forum/dl/post/5386327/3.jpg
http://4pda.ru/forum/dl/post/5386328/4.jpg
http://4pda.ru/forum/dl/post/5386329/5.jpg
http://4pda.ru/forum/dl/post/5386332/8.jpg
http://4pda.ru/forum/dl/post/5386333/9.jpg
http://4pda.ru/forum/dl/post/5386334/10.jpg
Прошивки Android 4.4.4 (800x480):
Заводские:
- 800x480(141126).rar (основана на 1024x600)
Кастомные:
- 20141125 (моя редакция)
Список изменений
Мои внесенные изменения:
- Заменен Ланчер на KGL-ный.
- DPI 220
- Заменил tzdate на версию 2014i (исправляет часовой пояс)
- Заменил Superuser на SuperSU.
- По умолчанию Русский.
- По умолчанию часовой пояс Москва +3.
- Добавил QuickBoot
- Добавил CarService
- Добавил TitaniumBackup в OEM
- Обновил Torque в OEM
- Добавил Torque_Widget в OEM
От автора прошивки (ИСТОЧНИК):
KVV_4.4.4_XRESxYRES_yymmdd_rooted_light_reparted_i nit.d_v4:
rooted:
- ClockworkMod's Superuser apk, su binary and root daemon (root daemon needed on 4.3+ roms)
reparted: (seems popular these days http://cdn3.xda-developers.com/images/smilies/wink.gif)
- system reduced from 768MB to 512MB
- oem reduced from 128MB to 64MB
- data increased from 1GB to 3GB
- internal sd in now a bit less than 4GB
removed apks:
- Gmail2 (available on Play Store)
- Maps (available on Play Store)
- GoogleSearch (available on Play Store)
- VoiceSearch (included in GoogleSearch on Play Store)
- Talkback (available on Play Store)
- Google TTS and its libs and files (available on Play Store)
- Adobe Reader and its libs (available on Play Store)
- Instructions (surely useless, not relevant and badly translated from chinese...)
- Chinese and Japanese Keyboards (also removed their libs that are now useless)
- Navgear (just a stupid shortcut to the selected nav app in settings...)
updated/added apks:
- Google Play Store (updated to latest version)
- Google Play Services (updated to latest version with libs correctly installed so no more Google Play Services errors! Fixed on 1024x600 thanks to @ESTIMULO)
- Browser bookmarks sync adapter (added, missing in KLD and KGL)
- Google calendar sync adapter (added, missing in KGL)
- Google contacts sync adapter (added, missing in KGL)
modded:
- init.d support added (late in boot process so every external storages are mounted), you can drop your scripts to /etc/init.d (chmod 755)
- added compatibility symlinks for storage mount points (it may fix issues with apps using hard-coded path to access sdcards and usb, if not it won't hurt anywway!)
- flash_image binary by Androtab, with dump_image and erase image symlinks to flash/erase/dump full partitions (dump_image return an error at the end but you can ignore it, dump is valid)
- KLD-4.4.4 от booroondook (истоник)
Сделал прошивку KLD-4.4.4 (пока с ядром от 4.4.2, поскольку других вариантов нет). Основа - XDA'шная "KLD_4.4.4_800x480_141126_rooted_light_reparted_init.d_v4".
Нововведений практически никаких - чуть подправил перевод, да убрал предустановку Adobe Reader'а.
А так все то же самое, к чему все привыкли.
- 14.04.2015
Прошивки Android 4.4.4 (1024x600):
Заводские:
- 1024x600(141126).rar
Кастомные:
Список изменений
- DPI 220
- Добавил QuickBoot
rooted:
removed apks:
updated/added apks:
modded:
post-7637-0-85074500-1418366364_thumb.pngpost-7637-0-33128500-1418366360_thumb.pngpost-7637-0-83406600-1418366361_thumb.png
post-7637-0-28574700-1418366359_thumb.pngpost-7637-0-27868900-1418366358_thumb.pngpost-7637-0-25143500-1418366357_thumb.png
post-7637-0-86030100-1418366362_thumb.pngpost-7637-0-66851900-1418366442_thumb.pngpost-7637-0-59115700-1418366446_thumb.png
Только MCU:
MTCB-GS-VX.XX
Инструкции по прошивке:
- Вариант 1 (простой).
1. Все делается на свой страх и риск
2. Сохраняем необходимые данные во внутренней памяти!!!
3. Извлекаем содержимое архива на карточку GPS. В корне карточки должен находится файл update.img и mcu.img
4. Вставляем карточку в магнитолу и подаем на неё питание, если она была выключена.
5. Когда магнитола будет полностью загружена, на экране появится табличка с предложением установить обновление. Жмем Install.
6. Магнитола перезагрузится в режим Recovery и будет заниматься процессом обновления примерно 5-7 минут (зависит от класса карточки)
7. После магнитола перезагрузится и первая загрузка займёт примерно 2-3 минуты.
8. После полной загрузки магнитолы, она снова предложит обновится т.к. файл на карточке ещё лежит. Просто жмём Canсel (левая кнопка, если вдруг будет все на китайском) и удаляем файл с карточки.
- Вариант 2 (через Recovery).
3. Жмём зажимаем кнопку RESET (кнопка в дырочке) + POWER (Крутилка громкости / MUTE)
4. Держим в течении 5 сек и отпускаем RESET, еще через 5 сек отпускаем POWER
5. Магнитола загрузится в режим Recovery. Передвигаемся по пунктам Крутилкой (поворотами или кратковременным нажатием)
6. Выбираем второй (2) пункт - update system/mcu image from sdcard
7. Жмём на Крутилку в течении 3-5 секунд. Начнётся проверка прошивки и дальнейшее обновление.
8. смотри пункт 7-8 из варианта 1
- Вариант 3 (через ПК / Ноутбук).
3. Необходимо скачать программу RKBatchTool
4. Необходимо скачать драйвера
5. Соединяем кабелем мини-USB магнитолу (порт OTG) и ПК / Ноутбук (USB).
6. Жмём зажимаем кнопку RESET (кнопка в дырочке) + POWER (Крутилка громкости / MUTE). Магнитола должна быть выключена, иначе не сработает RESET.
7. Держим в течении 5 сек и отпускаем RESET, еще через 5 сек отпускаем POWER
8. На магнитоле загорятся кнопки но экран будет чёрным. на ПК / Ноутбуке в программе RKBatchTool определится устройство.
9. В программе RKBatchTool выбираем прошивку и жмём Восстановить.
10. Дожидаемся окончания прошивки, выдергиваем кабель из разъема OTG и жмём RESET.
11. Магнитола перезагрузится. Покажет андроида, чуть-чуть подумает, снова перезагрузится и все Готово!
Очень ВАЖНО
Существует множество разновидностей китайских магнитол с разными MCU (GS/KGL/GLD/JY) и определить это можно в информации об устройстве. На данный момент мне известно, что для магнитола Emgrand EC7/RV версия MCU обозначается как GS (MTCB-GS-vX.XX). Прошивка MCU от другого устройства не критична, но функции кнопок на магнитоле будут совершенно другими. К примеру кнопка NAVI будет запускать музыку, а кнопка DVD будет открывать меню.
Последствия неудачных прошивок:
1.Если прошить магнитолу прошивкой не с тем разрешением, то изображение на экране будет сдвинуто вправо-вниз (в случае прошивки 1024*600 на 800*480). Последствия обратного не видел. рассказать не могу
Примеры:
http://youtu.be/nBET62Z7sYs
http://www.geely-club.com/forum/uploads/monthly_12_2014/post-7637-0-13104300-1418378818.jpg
2. Если прошивка не от этого устройства или во время прошивки произошёл сбой, в лучшем случае у Вас будет показано начальное лого или логотип загрузки. Если в этом случае загрузка в режим Recovery не будет работать, нужно воспользоватся 3-тим вариантом прошивки.
3. Ещё возможно, что прошивка прошла успешно, но при включении габаритов и подсветки магнитолы, а так-же при включении задней скорости, экран просто гаснет и не включается. Нужно выключить габариты/з.скорость, перезагрузить магнитолу через RESET или вытащить ключи на 1 минуту, и снова перепрошить магнитолу.
Полезные программы:
CarService - Взаимодействие кнопок на руле со сторонними проигрывателями. (ИСТОЧНИК)
AKA GALA - Синхронизация звука со скоростью. Чем выше скорость, тем громче звук. (ИСТОЧНИК)
Microntek сервис магнитолы - аналог CarService но с дополнительными плюшками.
Полезности:
Фикс работы автоматической смены дня и ночи в Navitel
Видео-обзор магнитолы с установленным Android 4.4.4 с разрешением 800х480:
Сообщение буду периодически обновлять.
________________________
* на сколько мне известно. Изменено пользователем Dangerous
Добавлена прошивка от 14.04.2015 800х480
  • Ответов 133
Олег молодчик! Нужная темка и актуальна! Есть вопрос по прошивке. Если ГУ прошита 4.2.2, то можно ли установить 4.4.2 и будут ли совместимы? И какое разрешение 800*480 или 1024*600?
Да, возможно. Я в первом посту все распишу что да как и прошивки 4.4.2 добавлю. Как начал тему писать, начали работой нагружать :be:
Я недельку сидел на 4.4.2 пока не вышла 4.4.4. Последняя ни чем не отличается, кроме того, что в последней заработала совместимость IOBD-адаптера с программой Torque. В 4.4.2 с IOBD нельзя было работать.
А вот с разрешением будет косяк. Если у тебя 800х480 а ты поставишь 1024х600 то будет вот-так:
Всем привет. Вопрос может не в тему, но появился у меня такой. Вот эти прошивки всякие для андроидной магнитолы, они к смартфону подходят или же нет?
@Олег2013,Нет, с телефоном прошивки не совместимы. Разное железо.
Могу добавить, у меня гу как на втором фото. Поставил плейер aimp, на флешку музыку формата FLAC, звучание супер, после выключении магнитолы запоминает последний трек, aimp включается сам. На штатной прошивке плейер не видит формат flac. Так что в теории форматы будет читать все, главное только прогу нужную.
Вот хотель бы самому поменять плейер вместо штатного, чтобы с кнопок руля переключать. Может кто сделает инструкцию.
@физик, Есть замечательная программа CarService созданная забугорными коллегами. Добавил в шапку "Полезные программы". Устанавливаешь, запускаешь и радуешься работой кнопок на руле в стороннем плеере.
Олег подскажи, скачал залитый архив 4.4.4 ( 800*600) и там только один файл update.а второго файла нет, почему? Обновлять прошивку этим одним файлом?
Андроид и MCU может обновляться отдельно. А для наших магнитол нет новых MCU, да и лучше версии 1.91 пока нет.
Отправлено с моего HUAWEI U9510E через Tapatalk
Понято, спасибо!
