Магнитола 2DIn слетел графический редактор
ДенисДенис
Все ответы объединил. Обсуждали только трое, поэтому поймём кому какой ответ. Можно было всё в одном сообщении написать. Разобрались бы, чай не маленькие. :bs:
  ДенисДенис сказал:
А что значит точный адрес?
Адрес производителя, его службы поддержки http://www.szwaywell.com/contact.asp
Это если магнитола точно такая...
спасибо
вот и у меня: балалайка на андрее... хз кто ее выпустил, когда и зачем....
никакой софт и никакой гугл не дали мне ответа на вопрос...
эх китай, такой китайский китай.
А уж с Андроидом-то какие проблемы?!)))) И какая разница кто ее выпустил, если она работает?..))))
  В 08.11.2017 в 18:50, Serg1609 сказал:
To begin with, let's clarify the moment - this is not a head unit! Thought from the salon, as you say. There are definitely a dozen types of similar Chinese radio tape recorders ...))) This is so that there is no confusion, since the regular one can be restored, there are update files. Read here for general understanding.
Would be nice to know which one you have...
You can approximately find this on Ali, look through the radio, find your own from the pictures, compare the desktop, design. Then write to the seller and culturally ask for the firmware. The Chinese are quite easy to make contact, it is quite possible that they will send. We can say that it was bought from him, and now it does not work, attach a photo of the screen. It's like an option.
The second method: go to the site w3bsit3-dns.com or w3bsit3-dns.com. The guys there are smart and will help!
The next option, which is also the simplest: turn off the radio from the power supply completely for several minutes (or hours), and then carry out a Reset by pressing the RES button with a toothpick on the front panel. If the shell has not completely flown off, then it should start ...
I have this tape recorder
And such a desktop radio
Do not pay attention to the running ResInfo program, it is separately installed, not from the radio!)))
Показать
To begin with, let's clarify the moment - this is not a head unit! Though from the salon, as you say. There are definitely a dozen types of similar Chinese radio tape recorders ...))) This is so that there is no confusion, since the regular one can be restored, there are update files. Read here for general understanding.
Показать
Would you please advice reset code ( 4 digest )
Показать
Would you please advice reset code number (4 digest )
Thanks
К сожалению, у меня уже давно нет этой магнитолы, да и этой машины тоже нет.))) Точно подсказать код не могу, не помню уже... Но обычно такие коды простые, типа 0000, 1234, 9999, и т.д. Можно просто пробовать перебором.
Может кто-нибудь подскажет из пользователей?)
PS Пробуй код 5588... У меня на магнитоле был такой, сейчас нашел в старых своих сообщениях.)
  В 16.11.2022 в 17:50, Serg1609 сказал:
Показать
Really appreciated brother it works with last code
